Re: McCormack WD9
Posted by Ron on October 15, 2001 at 07:17:01 from (155.226.255.42):
In Reply to: McCormack WD9 posted by Wayne on October 13, 2001 at 16:23:40:
You bet it's tough and it usually means that the rear main bearing is worn too. If the main is worn and you replace only the seal the leak will be back soon as the worn main allows the crankshaft to tear up the new seal pretty quickly. Speaking from experience here.
Post A Followup
: Re: Re: McCormack WD9
