Re: 1206 rear seal
Posted by the tractor vet on October 16, 2001 at 18:27:37 from (216.196.13.212):
In Reply to: 1206 rear seal posted by ihdoug on October 16, 2001 at 08:41:24:
It might not be the rear engine seal that is leaking, it might be that the input seals on the shafts are leaking i have found this to be the case on a lot of supected rear engine seal leaks . You will need to replace both input seals and i would also recomend replacing the PTO bearing as this bearing can get exsive ware and become to sloppy for the PTO seal to hold.
Post A Followup
: Re: Re: 1206 rear seal
