Re: Farmall C engine in a BN?
Posted by farmalldan on October 17, 2001 at 12:08:51 from (64.154.26.248):
In Reply to: Farmall C engine in a BN? posted by Larry on October 17, 2001 at 09:49:38:
Larry,
I believe the engines are essentially interchangeable, but you need to be aware of one little "uh-oh" before you get it put together. "A"'s and "B"'s have the bolts which hold the steering gear housing to the front face of the engine inserted from the rear. This means the steering gear housing is threaded. On the "C", Super "A", etc., the hydraulic pump covers the upper hole on the right side. This bolt is inserted from the front. This means the block is threaded and not the steering gear housing. You will need to drill the threads out of the steering gear housing before assembly and everything works. I'm working from a poor memory here, so check out which holes are threaded and which are not in both block and steering gear housing before you start putting together and make appropriate modifications. With a torque tube from a Super "A", you can add the hydraulic lift and have a Super "B".:>)
Danny
Post A Followup
: Re: Re: Farmall C engine in a BN?
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
