Re: Re: Farmall M - Low compression
Posted by walt f on October 17, 2001 at 21:52:03 from (24.159.78.57):
In Reply to: Re: Farmall M - Low compression posted by brianh on October 17, 2001 at 14:43:49:
if you've got a magneto it should crank by hand.i use this method to examine each phase of the engine start up. crank slowly, checking for fuel drip (when choked),from the bottom of the carb.,check for spark,holding the sparkplug end of the wire at least 1/4 in. from ground. if you've got fuel and fire (and the timing is right)it will start and run
Post A Followup
: Re: Re: Re: Farmall M - Low compression
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
