Re: Re: IH 806 Opinions
Posted by ihdoug on October 18, 2001 at 10:25:28 from (209.206.208.203):
In Reply to: Re: IH 806 Opinions posted by Farmer-Gene on October 18, 2001 at 09:40:39:
Iv'e heard many times that the 06 series was a very sound series. I have a 1206, very similer to the 806, and Have experienced the sloppy shifting. The linkages can be adjusted. If the tractor seems to grind a while when shifting into high/ low / Rev. Adjust the transmission brake. Adjustment is on right of tractor, alongside housing. Adjust clutch, and TA dump valve first, as they will affect the Brake adj. Keep these things in mind if you test out the tractor or other IH tractors, as sloppy shifting seems to be an unfortionate trait of them, atleast the ones I see.
Post A Followup
: Re: Re: Re: IH 806 Opinions
