Re: farmall h hydraulics
Posted by Les Repair on October 18, 2001 at 17:24:22 from (206.28.174.76):
In Reply to: farmall h hydraulics posted by sgrider on October 17, 2001 at 08:16:56:
Better check the pressure first. Some of these pumps are getting pretty tired. I'm not sure of the pressure, but should be in the 1000 PSI range. Some people do put a washer under the relief valve spring.
Post A Followup
: Re: Re: farmall h hydraulics
