Re: How do you check a voltage regulator?
Posted by gene b on October 18, 2001 at 19:38:03 from (63.42.174.2):
In Reply to: How do you check a voltage regulator? posted by JW(NC) on October 18, 2001 at 19:02:15:
easiest way to check is ground the field if that makes it charge the reg is bad if it doesent charge with the field grounded the gen is bad it is wise to get a new reg if the gen is replaced not all regs are for all gen they must be the correct match
Post A Followup
: Re: Re: How do you check a voltage regulator?
