Re: Radiator swapping
Posted by gene b on October 18, 2001 at 19:50:31 from (63.42.174.2):
In Reply to: Radiator swapping posted by Will on October 18, 2001 at 08:10:28:
the bottom of the C mounts different than a B but better check the mounting holes to see if the spacing is the same the B has a threaded stud going into the radiator where the C has two carriage bolts that slide in to the bottom of the radiator what year B do you have if you have the 1/4 turn hex head fasteners they will not work best way is to put them side by side and you will see what I am trying to explain
Post A Followup
: Re: Re: Radiator swapping
