Re: Farmall 340 No Go ShowBoat
Posted by Eric on October 19, 2001 at 09:19:48 from (216.86.65.74):
In Reply to: Farmall 340 No Go ShowBoat posted by Tim C.(MI) on October 09, 2001 at 18:02:38:
Tim, I have the same problem on my Farmall 340 and have tried everything I could think of to get it to work. I ended up taking a short piece hyd hose & by-passing with one of the valves. Not the correct fix but it got me in the field. If you figure anything out, let me know and I will do the same. Thanks & Good Luck. Eric
By the way, where in michigan are you?
Post A Followup
: Re: Re: Farmall 340 No Go ShowBoat
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
