Re: 140 3 point adapter
Posted by George Steele on October 19, 2001 at 11:05:47 from (152.163.188.229):
In Reply to: 140 3 point adapter posted by mcdanl on October 18, 2001 at 19:04:10:
I have 140 with 3 point and have had no problems.
I don't have front wheel wts and everythings stays on the ground. I use small disc and 5 ft bush hog as well as a spreader that holds about 400 lbs. I did need longer drive shaft on the spreader but that was not a major problem. All this stuff works much better on level smooth ground but can be made to work on rows of trees that are planted with a bedding plow. Be safe!
Post A Followup
: Re: Re: 140 3 point adapter
