Farmall Tractors Discussion Board
Re: Would the C123 motor enable me to use the 2 bottom plow w/ Super A?
Posted by Lowell on March 07, 1999 at 15:08:00:
In Reply to: Would the C123 motor enable me to use the 2 bottom plow w/ Super A? posted by Daniel on March 07, 1999 at 14:26:59:
It is the same motor as the Super C.
I think the plow is 12", so it should pull a 2-12 plow execpt in the hardest of soils.
You may need to add some weight to the tractor.
I add 1000 pounds to my B when plowing with a 2-12 pull type.
Post a Followup
: Re: Re: Would the C123 motor enable me to use the 2 bottom plow w/ Super A?
