pnuematic lift help
Posted by W.W. on October 20, 2001 at 15:08:52 from (209.240.222.132):
my lift on my B would not go down so I took the valve apart and cleaned it, now it doesn't stay up the rubber washer was swollen up some. is that my problem if it is where can I get one?
Post A Followup
: Re: pnuematic lift help
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
