Re: M Clutch...Update
Posted by Doc on October 21, 2001 at 21:12:17 from (209.98.95.60):
In Reply to: M Clutch...Update posted by Dave from MN on October 21, 2001 at 10:07:20:
While you are in there, check the seals on the front of the transmission, the input shaft and the countershaft. They are easy to change and readily available. The seal on the drive for the belly pump could be changed now also. I like to do what I can while things are apart. Good luck. Doc.
Post A Followup
: Re: Re: M Clutch...Update
