Re: 300utility fuel problems
Posted by Lance on October 22, 2001 at 04:18:08 from (199.46.198.233):
In Reply to: 300utility fuel problems posted by duane on October 21, 2001 at 20:10:25:
Just took the tank out of my 300U to get the fill neck repaired. With the neck out of the tank I was able to see the baffles that are in the tank, one appears to come up about halfway on the backside of the tank just behind the fill neck. Perhaps crud is blocking the transfer holes under the baffle plate restricting fuel flow after you get below 1/2 tank.
It's a real pain to remove the tank if you can't get the steering wheel off so you can remove the dash but can be done. To do so remove the front tank mount and the valve cover, pull the dash up the steering colum as far as you can and remove the tank by pulling it forward and off the right side.
Post A Followup
: Re: Re: 300utility fuel problems
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
