Re: Hydraulic lift
Posted by Haas on October 22, 2001 at 06:01:53 from (129.37.117.110):
In Reply to: Hydraulic lift posted by ed herrick on October 21, 2001 at 18:31:16:
Does the engine sound like it is under load all the time??? Is the hydraulic unit getting hot?? If it is getting so hot you can't touch it, something is wrong. Maybe something is stuck or not adjusted properly and the system is on high pressure all the time. You can get a kit for the pump and the unit at a Case IH dealer. The pump is pretty easy. The Touch Control Unit is a lot more complicated. You will definitely need a manual before you try to tackle it.
Post A Followup
: Re: Re: Hydraulic lift
