Re: Gas tank sealer?
Posted by Haas on October 22, 2001 at 18:19:56 from (129.37.117.61):
In Reply to: Gas tank sealer? posted by Paul Shuler on October 22, 2001 at 10:39:33:
I used the Eastwood Sealer in the tank on my C with very good results. I did not have a problem with crud, but rather a leaking tank where the brackets are welded on. The sealer have been in there several months now and no problems. I bought the sealer "kit" from Eastwood which as I recall was 39.99 plus shipping. There is the sealer and I believe a cleaner and a conditioner. Also, be aware you have to go to a hardware or home supply store and buy a can of acetone and a jug of muratic acid. These are called for in the Eastwood instructions. Total cost by the time you get done is around $60. Also, be sure to wear heavy duty rubber gloves and eye safety equipment when using this stuff, especially the muratic acid. Disposal of the muratic is also a problem, I neutralized mine with lime. Be careful doing that and pour the acid slowly into a large bucket containing some lime and several gallons of water.
Post A Followup
: Re: Re: Gas tank sealer?
