Re: Re: Super A main bearing replacement
Posted by Stan(VA). on October 23, 2001 at 05:38:35 from (207.172.109.88):
In Reply to: Re: Super A main bearing replacement posted by gene b on October 22, 2001 at 19:05:23:
I just did this on my Super M. I loosened all the main caps, then removed them one at a time for bearing replacement. This also helps make sure you woln't accidently swap the position of any of the caps. The main (as well as the rod) journels are machined as a pair and cannot be swapped to another position!!! I have seen two tractors now that this has happened on and the results are never good. To help get out the upper inserts, use a nail with the head sticking out of the oil hole and gently rotate the crank so that the insert comes out notch side first. Install the new insert by rotating the crank the other way until the notch is in it's place. Stan(VA).
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
