Re: 300 Utility hydraulics
Posted by NEAL S. on October 23, 2001 at 13:09:20 from (216.165.148.55):
In Reply to: 300 Utility hydraulics posted by brian on October 22, 2001 at 15:53:19:
Brian, it would probably be best to check your fluid reservoir after having run it and warming it up. pull the dip stick and check the opening to see if the oil is foamy, a good indication of worn pump,or fluid bypassing somewhere. I believe the reservoir is located under the seat on that machine. if so you may have a plugged intake screen located under that cover you sit on. you know what that means, but don't fret i've done it many times and it still isn't easy but has to be done. other than that it would be the valves or the auxiliary valve on the valve bank. Good luck.
Post A Followup
: Re: Re: 300 Utility hydraulics
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
