Re: H Fan belt cross reference?
Posted by John A on October 23, 2001 at 17:38:26 from (208.24.232.24):
In Reply to: H Fan belt cross reference? posted by Salmoneye on October 23, 2001 at 05:23:27:
Salmoneye, Don't know if you know this but to adjust the tendion on the water pump. Loosen the
set screw on the frount half of the pully ,unscrew
the frount half to widen the gap so the belt can be set in place. screw the frount half back to tighten the belt. There are slots in the threads,
when desired tension is achieved find slot closest
the retighten the set screw , there you are!
You mentioned you usually hung out on the Ford
site , that's why I placed this note to you.
Hope it helps!!!
Post A Followup
: Re: Re: H Fan belt cross reference?
