Re: 300U PTO rear housing fluid
Posted by Ace Schrunk on October 24, 2001 at 05:06:13 from (207.232.79.81):
In Reply to: 300U PTO rear housing fluid posted by Lance on October 24, 2001 at 04:26:24:
HyTran all the way even PTO you will have to change the PTO by is's selfe as for the TA and rear end drain all plugs and fill all through the fill in thr rear end deck
Post A Followup
: Re: Re: 300U PTO rear housing fluid
