Re: 806 Shifting Problems
Posted by NEAL S. on October 24, 2001 at 11:45:45 from (216.165.155.119):
In Reply to: 806 Shifting Problems posted by 911-806 on October 24, 2001 at 08:17:06:
I would believe that the roller or bushing that fits on the pin on your shift fork either broke was not installed or the cam spring under the shift cover is broke. with floor pan removed see if their is freedom on the shift lever with link pin removed. Good luck.
Post A Followup
: Re: Re: 806 Shifting Problems
