Re: proper service of my M
Posted by The Red on October 25, 2001 at 14:56:24 from (12.84.242.31):
In Reply to: proper service of my M posted by Steve Wilkens on October 25, 2001 at 14:45:01:
Steve on the rear lube, the M takes 13 GALLONS of 90W or 85W-140. I use whichever one is in stock at the local farm store. I drain the M in 3 places. You have the rear plug underneath the PTO. Have FOUR 5 gallon buckets ready just in case someone had overfilled it. Also there is a front drain plug on the transmission underneath the inspection plate next to the hydraulic belly pump. You will get a quart or so out of that drain hole. I also remove the 3 bolts on the flat belt pulley assembly and tap the pulley out 1/4" or so. You will get 1/2 quart of 90W and water. Condensation has a tendency to migrate up to the belt pulley assembly. It is purposely designed to hold 90W that is sloshed up from the transmission. The fill plug for the transmission/rear end is that large diameter plug between the steering post and the brake pedals. Use a 3/4 drive of some sort to remove it. Clean that area good before you remove it. Save about 1 quart of the new 90W and pour it in the inlet hole on top of the flat belt pulley assembly. The excess will simply run back into the transmission. I use teflon tape on all the plug threads. Make sure you install the drain plugs before you start filling it!!!!!!!!!!!!! If you have the hydraulic belly pump, the drain plug is on the bottom. It holds 6 quarts of non-detergent SAE30.
Home
| Forums
Today's Featured Article -
The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
