Well, that depends. The 3788 did not come with dual pto so some one may have taken care of any internal shaft size changes couplings already . One other thing, there are two different dual pto units, early ones have adjustable pressure engagement valve stem that is pulled up for engage with spring loaded brakes when shut off so shaft will not turn with or without engine running. Later one has hydraulic locked engage with valve spool pushed down in to unit, hydraulic shaft brake that is applied when engine is running and pto shut off but shaft is free to turn when engine is not running. Either unit will fit and work but they have opposite operating lever linkage so you need correct linkage for your unit and correct size and length of internal shaft and couplings. .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
