Re: Re: Re: New Rod Bearings didn't work!
Posted by Stan(VA). on October 26, 2001 at 05:00:41 from (207.172.109.68):
In Reply to: Re: Re: New Rod Bearings didn't work! posted by Dick Davis on October 26, 2001 at 04:18:32:
Dick,
What did the old inserts look like when removed? any copper showing? Are all the rod caps with the correct rods? If you didn't notice the rods being loose when reinstalled, you might want to keep looking until you isolate it. It's usually harder to find a low oil pressure problem when nothing is knocking yet. If it's loud enough to knock, you should be able to find what's loose. Maybe use a dowl like a stethescope(sp?) and locate the source as high/low front/back in the motor. Other possibilities could be the small end of the rods (when you drop the rod cap, is the piston loose on the rod?); valve train/rocker troubles (usually a slower knock, 1/2 of engine rpm); timing gears can come loose on the crank or cam ...
And then there's your real problem, which is always the last thing I come up with ;-)
Good Luck,
Stan(VA).
Post A Followup
: Re: Re: Re: Re: New Rod Bearings didn't work!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
