Re: Rear Rim to Hub Clamps - Proper way to attach?
Posted by The Dukester on October 27, 2001 at 05:16:37 from (216.93.118.172):
In Reply to: Rear Rim to Hub Clamps - Proper way to attach? posted by Brad Whitty on October 26, 2001 at 23:12:44:
Yeah, the jam nut is needed to keep the clamp assembly located around the wheel center. If you leave the jam nut off, the rim clanps can "float" back and forth the 1/2-3/4" slack in side loaded conditions like in the furrow plowing. Put it all together like it was designed and you shouldn't have any trouble. Tighten all of it really tight!
Post A Followup
: Re: Re: Rear Rim to Hub Clamps - Proper way to attach?
