Re: FARMALL SUPER C - WINTERIZING
Posted by Farmer Bob on October 28, 2001 at 16:43:50 from (66.152.73.254):
In Reply to: FARMALL SUPER C - WINTERIZING posted by GEORGE on October 28, 2001 at 15:44:20:
George, A lot depends on whether or not the tractor will be garaged during the winter and how cold your "Winter" is going to be. First on oil, I'd recommend SAE 20W oil if the temps are suspected down around zero to 20 above F. SAE 30W would be fine for temps above freezing and tractor is shedded. To service the oil filter, drain the housing below the filter and then remove the filter cover and slip in a new filter. Make sure you replace the "O" ring seal that the cover rests in as it is probably very old and hard. A new seal should come with the filter and you'll have to dig the old one out making sure it is all out before inserting the new seal. The new seal will go in easily if you coat it with motor oil before installing. For anti-freeze, premix a 50/50 solution of anti-freeze and water. Drain the old stuff out of the drain tube that sits below the bottom radiator hose connection between the engine and the radiator. Turn the tractor over with the hand crank a few turns and most of the block will be drained as well as the radiator. Plug the drain and fill the radiator with the 50/50 mix. If you will be using the tractor as a chore tractor during the winter, you may want to install a tank heater which will keep the anti-freeze/water warm and the engine won't be bone cold when you go to start it. If the tractor is still 6V system, ensure you have it well tuned up to ensure quicker cold start-ups. Others may add to this list as I probably forgot something.//FB
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
