Re: FARMALL SUPER C - WINTERIZING
Posted by Jason on October 28, 2001 at 16:58:19 from (66.79.16.123):
In Reply to: FARMALL SUPER C - WINTERIZING posted by GEORGE on October 28, 2001 at 15:44:20:
If you are in the cold weather, I would use 10W-30, or 15W-40. I think the multi-viscosity is better in the winter, or all year long for that matter. I run 15W-40 in all of my tractors, the C included. The anti-freeze you do mix, but do not exceed a 70% solution. The oil filter is a Fram #C135. Make sure you drain your gas tank, sediment bowl, and carb. Refill with fresh gas and add some dry gas.
Post A Followup
: Re: Re: FARMALL SUPER C - WINTERIZING
