300U Hydraulics
Posted by Robert on October 29, 2001 at 16:05:51 from (63.208.91.149):
Having trouble with hydraulics/engine. Engine seems to bog down when clutch is released. I have found that if I start to raise the hitch the engine smooths out until the hydraulic piston bottums out.
I have been told that the hydraulic strainer is clogged. Has anyone else run into this problem?
Thanks,
Robert
WPB, FL
Post A Followup
: Re: 300U Hydraulics
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
