Re: 300 with broken rear axle
Posted by Tim Shaw on October 29, 2001 at 19:38:36 from (209.74.226.19):
In Reply to: 300 with broken rear axle posted by LB on October 28, 2001 at 20:34:32:
If I remember correctly there were two different axle diameters in the Farmall 300s. I think the smaller was the same diameter as the H but I'm not sure one from an H would fit.
Post A Followup
: Re: Re: 300 with broken rear axle
