Re: Farmall H Distributor
Posted by The Red on October 31, 2001 at 03:27:24 from (12.84.239.210):
In Reply to: Farmall H Distributor posted by Clint Wolske on October 30, 2001 at 20:42:47:
Clint turn the engine until you have the #1 piston on top dead center on the compression stroke. Whether you have the horizontal or the Delco Remy aftermarket vertical distributor, I usually install them so the rotor is pointing around the 1:00 position but that is only technique. After installing, turn the distributor base so the points just crack open. Wherever that rotor is pointing at this time, the corresponding post on the distributor cap should be wired to #1 spark plug. Then wire clockwise 3,4, and 2.
Post A Followup
: Re: Re: Farmall H Distributor
