Re: F-12, F-14, F-20 WEIGHT
Posted by Bama Binder on October 31, 2001 at 12:15:55 from (206.5.110.200):
In Reply to: F-12, F-14, F-20 WEIGHT posted by RICK JACOBS on October 31, 2001 at 11:22:30:
From memory, it seems like the basic weight on the F-12s and F-14s is between 3000 and 3500 pounds. The F-20s be between 4000 and 4500. If your trailer is a heavy duty trailer with 2 3500 pound axles and brakes, you should be able to transport the F-20 pretty easily.
Post A Followup
: Re: Re: F-12, F-14, F-20 WEIGHT
