Re: 1941 M Serial Number
Posted by Haas on October 31, 2001 at 13:12:42 from (129.37.117.2):
In Reply to: 1941 M Serial Number posted by Brad on October 31, 2001 at 05:50:19:
The two way hydraulics could be original. Not sure if it was offered from the beginning, but a 2 way spool valve was optional on the M. The valve was located in front of the belt pulley and was mounted to the fill opening of the lift all unit with a pipe tee and connected to the pressure outlet of the lift all with a hose. It was operated by a second pull rod that was mounted beside the operating rod for the lift all. To use the two way hydraulics, you locked the lift all rod in lift position so that hydraulic fluid was pumped through the spool valve. If yours is like that, it is likely original. If the valve is mounted elsewhere, like on the light bar or such, then it is an add on.
Post A Followup
: Re: Re: 1941 M Serial Number
