Re: Re: Re: Re: Re: Farmall M-four bottom?
Posted by Denny Frisk on October 31, 2001 at 19:27:56 from (216.165.151.3):
In Reply to: Re: Re: Re: Re: Farmall M-four bottom? posted by Ralph on October 31, 2001 at 17:35:32:
Yup, Low gear at about 2-1/2 MPH will have about 140% of the torque that 2nd gear would have in the final drives. I've seen LOTS of stuff break at tractor pulls, everything from blown tires, broken wheel hubs, twisted shafts and stripped gears But Yes, I've pulled M's & H's as hard as they would go in Low gear, and they're still running. Low is located as far away from the pilot bearing as they could put them in the transmission. For a good reason. Look at S-E Mich. Part-Timer's post, He's broken a pilot bearing off. Yes, it's harder on the pilot bearing to run in 4th than 2nd, but if You go trying to plowing up rocks with an IHC #8 you'll tear the plow up LONG before you blow up the transmission in the M. Want to hear the story about the M that had the head shaved .125" instead of .030" to raise compression? Tractor would NOT pull down with 3-14's. Only M crankshaft I ever saw broke clean into 2 pieces! I worked for the guy that owned the tractor and saw the crankshaft. Only time I ever heard of that happening! Dad's '51 M has the big M&W sleeves & pistons in it and We always plowed with it in 3rd in sod & 4th in corn stalks without a problem. There's a reason why Fuller, now called Eaton puts the driving gear between 2 driven gears in the big truck transmissions, to equalize the bending forces that cause the pilot bearings to snap off. You can get by with most things for a while, but you lean on the equipment too long and somethings going to break! In sandy soil or light peat ground 4-14's may be O-K for an M. But I still say 3-14's a gear higher would stress the rear end and transmission less and still get as much ground plowed.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
