Re: Front end loader on h
Posted by john d on November 03, 2001 at 14:47:22 from (64.12.102.171):
In Reply to: Front end loader on h posted by Farmall ED on November 03, 2001 at 09:01:22:
Your H can do a LOT of work with a loader. Increasing the front tire size to 6:00x16 goes part of the way toward making it steer decently. The steering will last longer if you simply don't turn it with a load on it unless you're moving. The first two places to show wear will likely be the thrust bearing under the sector gear at the top of the front bolster, and the little ball bearing on the end of the steering shaft where it exits the steering gear box at the front of the bolster. Keep the loads low when moving, go slow for safety, and NEVER let anyone ride in the bucket. To plumb the cylinders, do as Red suggested and run a line from the right outlet port and the front one on the left to the two cylinders. You will not, however, need return lines to the filler port if you simply put a "breather" plug in the top ports of the cylinders. These are available at farm supply stores or implement dealerships. The cylinders will only provide lift using the belly pump. There is no down-pressure unless you add some additional valves.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
