F-14 front wheel
Posted by george goodwin on November 03, 2001 at 17:30:12 from (24.24.88.233):
When one removes the front wheel, there are 4 bolts that pass through the wheel. Is it necessary to remove the bolts and split the wheel to change the tire. thank you...George
Post A Followup
: Re: F-14 front wheel
