Re: M-Clutch questions
Posted by Haas on November 05, 2001 at 12:36:02 from (64.12.103.28):
In Reply to: M-Clutch questions posted by Dave from MN on November 05, 2001 at 07:26:17:
When you depress the clutch pedal, after there is about one inch clearance between the clutch pedal and the tranny housing you should start to feel resistance. The initial resitance you feel up to the firs inch, is just the spring that pulls the clutch pedal back against the transmission housing. After that first inch, you are then depressing the clutch springs. I hope you have not put the Lift all Unit back in yet! If it is still out, then get down under the tractor with a light and look up in there while someone pushes in the clutch. (without the tractor running) you should be able to see the throwout bearing contacting the clutch levers. With the clutch all the way engaged, there should be 3/16" (going from memory) clearance between the clutch levers and the throw out bearing. If it is more than that, you need to adjust the rod at the clutch pedal, or maybe the clutch levers. The clutch levers should be set so that all three contact the throw out bearing at the same time. If you had the clutch rebuilt at a shop, they should have set them for you. Hope this helps let me know what you find. Also, I assume you have a manual and have all the parts in there correctly, including the clutch release carrier, etc.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
