Re: Carburetor
Posted by pete 23 on March 15, 2009 at 21:00:45 from (173.87.1.12):
In Reply to: Carburetor posted by Farmall Bob on March 15, 2009 at 19:59:07:
As there are a number of different carter carbs used on these tractors, it is difficult to give a measurment. Ordinarily the float should be parallel to carb base. A lot of these needle and seats do not hold well. I like to take some measure to assure they do. If it has a viton tip needle I will coin the seat with a "suitable" tool. I usually use an old valve from an injection nozzle tip. If it is a steel tip I coin it.
