Re: 460 farmall belt alignment problem
Posted by kev@ia on November 05, 2001 at 15:56:03 from (206.72.15.225):
In Reply to: 460 farmall belt alignment problem posted by charlie warren on November 05, 2001 at 11:21:23:
Read your post and went out and m checked my farmall, a 1/2 inch bolt fits between the top of the pulley and the front cover of the motor, 2 groove pulley.
Hope this helps
farmer kev
Post A Followup
: Re: Re: 460 farmall belt alignment problem
