Re: Re: Hydraulic oil level
Posted by Dick Davis on November 06, 2001 at 03:10:11 from (205.188.192.51):
In Reply to: Re: Hydraulic oil level posted by Redtractorman on November 05, 2001 at 20:53:40:
They came with a dip stick to check the level at the fill neck but many have been lost over the years. The one on my H is 9 1/2" from the top of the fill pipe to the fluid level, an M would be approximately the same. Overfilling somewhat is not a big problem because the belly pump is also an expansion tank for the system. What are you using for fluid? 30wt non detergent motor oil is what the book calls for. Hope this helps, good luck. Dick
Post A Followup
: Re: Re: Re: Hydraulic oil level
