Re: Wiring diagrams -- '56 Farmall 300, '49 Farmall cub
Posted by Bob M on November 07, 2001 at 09:27:27 from (165.170.128.65):
In Reply to: Wiring diagrams -- '56 Farmall 300, '49 Farmall cub posted by doug vose on November 06, 2001 at 19:40:22:
Doug - Punch the link below - you should find a diagram that will work for your Cub. Unfortunately I don't yet have any wiring diagrams for the "hundred" series tractors. However if anyone has one to share I'll gladly add it to my collection in Photopoint.
I've never messed with a Case DC. However my experience is most gas-powered IHC, Deere, M-M and Oliver tractors built from 40's thru mid-50's and equipped with Delco electrics are wired pretty much identically. Gotta think your Case DC is the same if it's got a Delco generator. Thus you can take a diagram for a 6 volt Farmall M and use it to wire up a Case DC with little difficulty. Only significant differences seem to be in ignition and light switch arrangements. For instance some mfr's (M-M and Oliver) used a single switch to control ignition and lighting vs IHC's separate ignition and light switches.
Post A Followup
: Re: Re: Wiring diagrams -- '56 Farmall 300, '49 Farmall cub
