Re: Re: Re: Ignition switch for 300 farmall
Posted by Pawnee on November 07, 2001 at 10:56:30 from (207.51.255.129):
In Reply to: Re: Re: Ignition switch for 300 farmall posted by Paul on November 06, 2001 at 19:26:30:
I suspect the ignition switch that you have could be bought at Walmart for $4 and change. It is labeled so you know how to wire it. The connections are screw on. It seems in the good old days they used parts that were generic in nature. Is one of the poles located in center with the other three located around it, only sort of sunken down and separated by plastic? If so then thats it. If not go with BobMs plan, he is the GURU on the electrically end. Good luck!
Post A Followup
: Re: Re: Re: Re: Ignition switch for 300 farmall
