Re: charging farmall M
Posted by Bob M on November 07, 2001 at 18:23:28 from (66.66.72.246):
In Reply to: charging farmall M posted by Joe Lehman on November 07, 2001 at 17:58:21:
Joe - "Normal" ammeter reading (with lights off) should be -2 to -4 amps at low idle (400 RPM), and anywhere from about +5 to +15 amps at full RPM. Actual maximum charge rate will vary depending on battery condition, generator temperature, regulator setting, etc.
It's normal for the ammeter needle to dance a little when the battery is being charged. However if it jumps around excessively suspect a bad regulator, or possibly worn brushes/commutator in the generator.
Post A Followup
: Re: Re: charging farmall M
