Farmall Tractors Discussion Board
Re: H sleeve puller and Website update
Posted by Clint Hofstetter on March 09, 1999 at 13:13:34:
In Reply to: H sleeve puller and Website update posted by The Red, John Fritz on March 07, 1999 at 09:18:50:
I think that a company called Owatana (sp?) Tools makes or has made sleeve pullers. They are quite pricy. Try to find a friend who works at a tractor or large truck repair place where they rebuild engines. If you can't find one, make a friend who has access to a puller. My local NAPA machine shop has the pullers for most sleeves. Check with them. Good luck on you sleeve pulling!
Post a Followup
: Re: Re: H sleeve puller and Website update
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
