Re: Re: Re: F-20 Cam Followers
Posted by Brad A (ore) on November 08, 2001 at 21:53:22 from (163.41.248.252):
In Reply to: Re: Re: F-20 Cam Followers posted by Mr. J on November 08, 2001 at 14:36:14:
Howdy Mr. J:
I don't know where my head was at last night, but it sure wasn't on my shoulders! Of course you have push rod, valve tappet guides. (part 405D, I think)
After you get the cam out and the lifters removed from the bottom, the valve tappet guides can be removed by
tapping them firmly with a drift from the pan end and they will come out through the top.
If you have a broken one, on the head end, it probably isn't to much of a problem and I would think that it could be repaired with JB weld.
A better solution may be to e-mail me off list with your address, and I will send you (give, as in gift) a replacement out of an old Regular that I scraped the motor from.
Brad A (ore)
Post A Followup
: Re: Re: Re: Re: F-20 Cam Followers
