Re: farmall tractor
Posted by Dave T on November 10, 2001 at 09:58:40 from (63.20.49.92):
In Reply to: farmall tractor posted by Walter Mott on November 10, 2001 at 09:39:13:
If it's not a Cub, it could be either....The B has either a trike front end, or narrow duals. The A has a wide front end, the engine seems to be offset from the tractor. The B has a long left rear axle, and the A axle housing is directly attached to the trans housing. The number you gave is a casting #, and is identical to A or a B. The ser. # tag is located under the seat inside the left seat bracket
Post A Followup
: Re: Re: farmall tractor
