Re: wide front H
Posted by Haas on November 11, 2001 at 17:11:35 from (129.37.117.209):
In Reply to: wide front H posted by Larry L. Walla on November 11, 2001 at 05:52:29:
Don't know, but I suspect the front end for the M was different (heavier) than the H. My M manual shows the IH wide front and that it could be installed in two positions, short or long wheel base. In the long wheel base postion, it is out front of the tractor. In short wheel base position, it is under the radiator. It shows an adapter plate for the short wheelbase position, not required if the long wheel base position is used.
Post A Followup
: Re: Re: wide front H
