Re: Carburetor
Posted by Hendrik on March 16, 2009 at 01:54:17 from (194.53.253.51):
In Reply to: Carburetor posted by Farmall Bob on March 15, 2009 at 19:59:07:
Don't know the level but if you have that figure, you can easily check correctness of fuel level using a simple bowl instead of the bottom half of the carb. See attached photo. Let it sit for a while and you can see if anything leaks. Fuel may leak between the base of the carb (body) and valve seat, while the needle does not leak.
