Re: How do you changing a starter ring gear
Posted by ScottyNY on November 13, 2001 at 05:04:15 from (128.59.6.129):
In Reply to: How do you changing a starter ring gear posted by Michael on November 12, 2001 at 17:47:05:
I had trouble getting lots of heat to remove mine. Got enough though to use a stout oak dowel to tap it off -- seemed like less chance of tearing things up with the dowel and it worked just fine. Came off a lot easier than I thought it would. Meantime, Sweety was out running errands while I had the new one in the kitchen oven, heating it to 500. That worked so well, I had a 1/16th or more slack when I laid it onto the flywheel. It did cool down nicely though, a good fit.
Post A Followup
: Re: Re: How do you changing a starter ring gear
