300u steering box-message for Big Fred
Posted by 300 Randy on November 13, 2001 at 10:34:01 from (66.84.135.51):
I got the steering box out last night. (4) bolts were sheared off and the other two were stripped.
The two dowel pins were sheared off to. The shaft coming out on right side was real loose. I tightened up that flange and there doesn't seem to be alot of play in it now. I might not have a real bad gear box after all. I have a machinist friend that will take a look at it. Whats your e-mail address Big Fred? I will keep you posted on my progress.
Post A Followup
: Re: 300u steering box-message for Big Fred
