Re: Difference between an A and a AV.
Posted by KurowNZ on November 13, 2001 at 13:11:26 from (203.96.111.200):
In Reply to: Difference between an A and a AV. posted by matt on November 13, 2001 at 04:51:27:
I have an A & AV. The differances are: 1. 32in rear wheels compared to 24. 2. Industrial front axle diamond shape as opposed to round.3. the arm the comes from the steering boc back to the bell housing. 4. you need a step ladder to get on it!!
All this provides an extra 51/2 in of clearance otherwise engine etx is the same as the A. Serial No on engine block and under left seat support will read FAAV.
Yes is rarer than the A, value is in the eye of the beholder.
Kurow.
Post A Followup
: Re: Re: Difference between an A and a AV.
